There's a few posts (all closed now) with folks asking, but seem to say they have a solution or even a partial solution.
Any ideas?
Sorry... "but none seem to say...."
Todd - we don't have any Rubrik kit so can't say with 100% certainty ... but the answer is almost certainly you can through the use of UnDPs. All you need are relevant OIDs for your kit and then you can build and test a UNDP. Once you know that works you can then build out an alert based on that UNDP.If you've not used UNDPs before then:Check this for basic UNDP build: How to Create a Universal Device Poller (UnDP) in NPM Check this for building an alert from a UNDP: Create custom poller alert in OrionWe do just this for a bunch of Fortinet kit.
Thank you for the reply.
Found out Rubrik has instructions on how to do the API process:
https://{{node_ip}}/docs/{{v1|v2|v3|internal}}/playground
Depending on the type of API you are looking for, you use the specific option: v1, v2, v3..etc
Thanks for all who reached out.
