Hello, is possible to add widget to modern dashboard where i could search maps ? I would like to see something like this:
You can certainly create your own "Table Widget" and hand code some SWQL to do just that.
Then just enable the search function on the widget, save and publish.Our preferred approach is a little widget on each node page (global view), that shows what maps that node appears on, a la:
