Hello,
Is there a way to have on the modern dashboard the same display of application alerts I have in original dashboard.
The appearance I want :
The apperance I have :
Sort of. You can't mix multiple links or links and non-links in the same "field."
Gut you can change the definition of the Applications field to display the status icon.
Here's an example from one of my modern dashboards. You just need to be aware that you'll need to pull in a Status, Link, and Name for everything you want to show like this.
