Solarwinds Version is 2023.4.2 .
I am Using the AppInsight for SQL. I am facing an Issue.
AppInsight components goes into unknow State and due to which Availability for the Database Instance is affected.
But actually, the Database Instance was Up and running.
Is there a way to ignore this, so that components does not goes into unknown state.
Is there a way to make the settings, so that it goes into unknown state, if i do not get the response for a component for 3 consecutive times.
Or
Is there a way to ignore, so that component never goes into unknow state?
