Does anyone know why the "Warning", "Critical" and "At Capacity" are showing Not Calculated?
Pretty sure they only do the calculation once a week and rely on having a week of historical data in the system, so my first guess would be that those volumes were added to orion too recently
Actually those volumes were added long ago like months ago.
I have the same problem, nobody seems to be able to explain why (not even Solarwinds tech support!).
Navigate to the volume details for those drives to be sure, but usually it's not calculated when the storage capacity forecast chart has a negative slope. If it has a negative slope, then it can't estimate a run out date since it is trending down instead of filling up. You can always open a support case and get an opinion if you check and this is not the case.
Thanks weston
