I'm trying to format an alert for scope utilization as seen below:
High DHCP Scope utilization | DHCP Server - SERVERNAME | Scope - SCOPENAME | Percent Used - PERCENTUSAGE
Using the article below and the "Insert Variable" within the alert configuration this is the content of the alert message:
High DHCP Scope utilization | DHCP Server - ${SQL: select distinct a.FriendlyName from [IPAM_DHCPServerReportView] a inner Join [IPAM_DhcpScopeReportView] b on b.ParentID= a.groupid and b.groupid = ${N=SwisEntity;M=NodeScope.GroupId}} | Scope - ${N=SwisEntity;M=FriendlyName} | Percent Used - ${N=SwisEntity;M=PercentageUsed}
The result is below. The friendly name and percent used populate data. The SQL statement from the article throws an error. I can't find a variable anywhere for the DHCP Server, which I found extremely odd. Am I using those correctly from the article or is there a standard variable to drop the DHCP server name?
IPAM DHCP Scope Macros for Alerts (solarwinds.com)
