Fairly new to Solarwinds SAM. We have one SQL Failover Cluster (3 nodes). We want to setup some type of email alert that will let us know when the cluster performs a failover. Can anyone point me to the best way to do this?
Thanks.
The easiest route is probably via an event log monitor against all 3There's a SQL route but it's awkward if they dont agree with each other
You can poll the AG for hostname too but awkward to do stuff quickly off that
I think the events live in: Microsoft-Windows-FailoverClustering/Operational and you want ID 1641Powershell run on the SQL server can pull it with: Get-winEvent -ComputerName ListnerName -filterHashTable @ {logname ='Microsoft-Windows-FailoverClustering/Operational'; id=1641}| ft -AutoSize -Wrap
And if you prefer to get the data from SQL look at: How to monitor SQL Server failover events automatically (apexsql.com) and use that to be a SQL query monitor.
Personally, @adam.beedell suggestion to pull the event is the easiest.
Thanks @jm_sysadmin for looking up the hard stuff, @ec.bryantu you can also stick that data into a solarwinds event log monitor and I can confirm it works fine without needing to write any code
