I believe Event ID 3041 should indicate a failed SQL backup job, that I would like to alert on.
Appinsight for SQL already collects logs from SQL server shown in the below widget - however it seems like a special monitor/component included with appinsight.
It is not a "normal" event log monitor.
How do I make an alert that triggers on a event id from this component? And why is failed SQL backup job monitoring not default from appinsight for SQL, do i overlook something?
Thank you in advance.
