We can add/remove columns as needed and the column width auto adjusts, we would like to manually resize the columns to give more room for the message column. How can this be done? Thanks.
Hello @r24x7 ,
currently, we offer only add/remove and reorder current columns. Please, post a feature request to support team for resizing of Events view.
Thank you
Did this request get submitted already? We are also looking for the same.**EDIT**: This is listed and open for voting for anyone else who comes across this post. [mention:c131ce164cb44c53a87db9a5bacbd954:fb5d84b10a5745448a7a45dafc1faa43]
Do not hesitate and submit your FR. More reference will make the item transparent like needed by bigger customer base.
Here's how to submit a feature request.https://support.solarwinds.com/SuccessCenter/s/article/Submit-a-feature-requestHere's a sample.https://thwack.solarwinds.com/t5/UDT-Feature-Requests/Agent-Polling-for-UDT/idi-p/570476
This is under UDT so you need to file this under Kiwi Syslog. reply to this thread with the link so that othe users can vote for it to pick up traction.
Thank you!
Wait, why would you want to be able to resize a column so you can actually read the information in it? You realize that manual column sizing requires wildly complex code... LOL.
For me, Syslog Server NG is useless if you can´t resize the columns. In our case, we only see some HEX-Numbering of a message and nothing more. Resizing columns is an elemantary feature of every Software.
I'm utterly shocked this has been a request for over a year and hasn't been done. This is one of the worst UIs and largest waste of space I've seen in a sys logger in a long time. You literally cannot even see the log data unless you hover over it or you remove all other fields. Really considering not purchasing this given in a year this simple but nearly expected feature set had to requested and hasn't been implemented. What an utter waste of space!!!
