Microwave WTM4200 - Connection Refused
I have a Microwave device that I connect to via SSH, it processes and saves all the configuration lines, but at some point it gets stuck in a loop.
[6183d626] [10/27/2023 10:44:27.718] -->usb-autoconfig enabled
[6183d626] [10/27/2023 10:44:27.718] Start check prompt for menu-based device
[6183d626] [10/27/2023 10:44:27.719] Process line = <usb-autoconfig enabled>
[6183d626] [10/27/2023 10:44:27.719] Fuzzy match detector start detecting prompt. String1=usb-autoconfigenabled String2=deposito_agua#
[6183d626] [10/27/2023 10:44:27.719] Save Command output: usb-autoconfig enabled
[6183d626] [10/27/2023 10:44:27.719] Process line = <>
[6183d626] [10/27/2023 10:44:27.729] -->(END)
[6183d626] [10/27/2023 10:44:27.729] Start check prompt for menu-based device
[6183d626] [10/27/2023 10:44:27.729] Process line = <(END)>
[6183d626] [10/27/2023 10:44:27.729] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:27.730] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:27.730] Pushing back: <(END)>
[6183d626] [10/27/2023 10:44:27.730] mPrompt is : <DEPOSITO_AGUA# >
[6183d626] [10/27/2023 10:44:29.551] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:29.551] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:29.552] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:29.552] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:29.552] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:31.566] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:31.566] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:31.567] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:31.567] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:31.567] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:31.568] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:33.568] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:33.568] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:33.569] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:33.569] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:33.569] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:33.570] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:35.580] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:35.580] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:35.581] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:35.581] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:35.582] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:35.582] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:37.596] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:37.596] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:37.597] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:37.597] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:37.597] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:37.598] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:39.611] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:39.611] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:39.612] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:39.612] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:39.612] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:39.612] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:41.627] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:41.627] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:41.627] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:41.628] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:41.628] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:41.628] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:43.629] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:43.629] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:43.630] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:43.630] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:43.630] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:43.631] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:45.642] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:45.642] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:45.642] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:45.643] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:45.643] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:45.643] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:47.659] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:47.659] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:47.659] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:47.660] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:47.660] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:47.660] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:49.675] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:49.675] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:49.676] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:49.676] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:49.677] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:49.677] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:51.690] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:51.690] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:51.691] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:51.691] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:51.691] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:51.692] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:53.708] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:53.708] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:53.709] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:53.709] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:53.709] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:53.709] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:55.722] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:55.722] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:55.722] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:55.723] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:55.723] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:55.723] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:57.737] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:57.737] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:57.738] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:57.738] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:57.738] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:57.738] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:44:59.739] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:44:59.739] Pending Disconnect = False
[6183d626] [10/27/2023 10:44:59.740] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:44:59.740] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:44:59.740] Removed data in (...) Output=
[6183d626] [10/27/2023 10:44:59.741] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:01.753] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:01.753] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:01.754] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:01.754] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:01.754] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:01.754] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:03.776] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:03.776] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:03.776] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:03.776] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:03.776] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:03.776] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:05.786] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:05.786] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:05.786] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:05.786] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:05.786] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:05.786] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:07.787] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:07.787] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:07.787] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:07.787] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:07.787] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:07.787] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:09.790] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:09.790] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:09.790] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:09.790] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:09.790] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:09.790] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:11.809] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:11.810] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:11.810] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:11.810] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:11.810] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:11.811] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:13.827] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:13.827] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:13.828] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:13.828] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:13.828] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:13.828] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:15.843] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:15.843] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:15.844] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:15.844] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:15.844] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:15.844] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:17.846] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:17.846] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:17.847] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:17.847] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:17.847] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:17.847] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:19.850] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:19.850] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:19.851] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:19.851] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:19.851] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:19.852] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:21.864] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:21.864] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:21.865] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:21.865] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:21.865] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:21.866] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:23.868] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:23.868] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:23.869] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:23.869] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:23.869] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:23.869] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:25.878] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:25.878] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:25.878] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:25.879] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:25.879] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:25.879] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:27.893] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:27.893] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:27.894] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:27.894] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:27.894] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:27.894] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:29.909] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:29.909] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:29.910] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:29.910] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:29.910] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:29.911] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:31.924] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:31.924] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:31.925] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:31.925] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:31.925] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:31.926] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:33.939] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:33.939] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:33.940] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:33.940] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:33.940] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:33.940] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:35.955] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:35.955] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:35.956] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:35.956] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:35.956] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:35.957] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:37.971] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:37.971] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:37.971] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:37.972] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:37.972] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:37.972] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:39.974] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:39.974] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:39.975] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:39.975] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:39.975] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:39.976] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:41.990] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:41.990] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:41.991] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:41.991] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:41.991] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:41.991] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:44.007] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:44.007] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:44.008] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:44.008] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:44.008] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:44.009] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:46.021] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:46.021] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:46.022] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:46.022] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:46.022] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:46.023] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:48.039] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:48.039] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:48.040] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:48.040] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:48.040] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:48.040] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:50.055] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:50.055] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:50.055] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:50.056] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:50.056] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:50.057] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:52.070] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:52.070] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:52.071] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:52.071] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:52.071] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:52.071] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:54.087] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:54.087] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:54.088] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:54.088] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:54.088] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:54.089] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:56.098] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:56.098] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:56.098] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:56.099] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:56.099] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:56.099] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:45:58.114] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:45:58.114] Pending Disconnect = False
[6183d626] [10/27/2023 10:45:58.115] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:45:58.115] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:45:58.115] Removed data in (...) Output=
[6183d626] [10/27/2023 10:45:58.115] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:00.129] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:00.129] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:00.129] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:00.130] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:00.130] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:00.130] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:02.147] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:02.147] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:02.148] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:02.148] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:02.151] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:02.151] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:04.165] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:04.165] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:04.165] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:04.166] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:04.166] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:04.166] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:06.179] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:06.179] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:06.180] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:06.180] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:06.180] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:06.181] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:08.194] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:08.194] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:08.195] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:08.195] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:08.195] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:08.196] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:10.208] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:10.208] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:10.209] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:10.209] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:10.209] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:10.210] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:12.222] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:12.222] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:12.223] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:12.223] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:12.223] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:12.224] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:14.237] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:14.237] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:14.237] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:14.238] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:14.238] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:14.238] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:16.239] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:16.239] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:16.240] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:16.240] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:16.240] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:16.240] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:18.254] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:18.254] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:18.255] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:18.255] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:18.255] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:18.256] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:20.278] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:20.278] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:20.278] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:20.278] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:20.278] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:20.278] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:22.292] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:22.292] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:22.292] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:22.292] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:22.292] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:22.292] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:24.303] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:24.303] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:24.303] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:24.304] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:24.304] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:24.304] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:26.317] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:26.317] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:26.318] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:26.318] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:26.318] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:26.318] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:28.331] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:28.331] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:28.332] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:28.332] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:28.332] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:28.332] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:30.346] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:30.346] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:30.347] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:30.347] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:30.347] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:30.347] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:32.348] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:32.348] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:32.349] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:32.349] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:32.349] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:32.350] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:34.362] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:34.362] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:34.363] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:34.363] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:34.363] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:34.364] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:36.364] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:36.364] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:36.365] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:36.365] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:36.365] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:36.366] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:38.378] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:38.378] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:38.379] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:38.379] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:38.379] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:38.380] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:40.393] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:40.393] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:40.394] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:40.394] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:40.394] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:40.394] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:42.395] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:42.395] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:42.396] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:42.396] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:42.396] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:42.397] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:44.409] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:44.409] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:44.410] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:44.410] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:44.410] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:44.410] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:46.424] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:46.424] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:46.425] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:46.425] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:46.425] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:46.425] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:48.426] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:48.426] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:48.427] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:48.427] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:48.428] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:48.428] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:50.440] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:50.440] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:50.440] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:50.441] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:50.441] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:50.441] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:52.455] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:52.455] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:52.456] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:52.456] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:52.456] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:52.456] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:54.472] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:54.472] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:54.473] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:54.473] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:54.473] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:54.473] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:56.474] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:56.474] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:56.475] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:56.475] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:56.475] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:56.475] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:46:58.489] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:46:58.489] Pending Disconnect = False
[6183d626] [10/27/2023 10:46:58.490] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:46:58.490] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:46:58.490] Removed data in (...) Output=
[6183d626] [10/27/2023 10:46:58.491] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:47:00.504] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:47:00.504] Pending Disconnect = False
[6183d626] [10/27/2023 10:47:00.505] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:47:00.505] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:47:00.505] Removed data in (...) Output=
[6183d626] [10/27/2023 10:47:00.505] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:47:02.520] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:47:02.520] Pending Disconnect = False
[6183d626] [10/27/2023 10:47:02.520] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any...
[6183d626] [10/27/2023 10:47:02.521] Fuzzy match detector start detecting prompt. String1=(end) String2=deposito_agua#
[6183d626] [10/27/2023 10:47:02.521] Removed data in (...) Output=
[6183d626] [10/27/2023 10:47:02.521] TimerTick: Just tick-tockin away ...
[6183d626] [10/27/2023 10:47:04.535] TimerTick: mstrData=<(END)> State=Connected
[6183d626] [10/27/2023 10:47:04.535] Pending Disconnect = False
[6183d626] [10/27/2023 10:47:04.536] TimerTick: Session Timeout Detected. Force disconnect
[6183d626] [10/27/2023 10:47:04.536] Force Disconnect
[6183d626] [10/27/2023 10:47:04.536] StateChange: Disconnecting
[6183d626] [10/27/2023 10:47:04.537] ERROR WODSSH: Timeout occurred due to inactivity.
[6183d626] [10/27/2023 10:47:04.537] Fire Session complete. Result: False
Timeout is high, so the message appears for about two minutes.
It's strange since there is no connection refused as such, because it can be connected to the device.
Do you have any idea what it can be?
Thanks in advance!
