Just installed SRM 6.1 yesterday. I did see something curious with volume usage. After I installed it, the basic alerts showed a lot of my volumes are over on disk usage.
On closer investigation I noticed something interesting. SRM seems to be using the statistic that includes total disk space used for Volume including the Replays. For most
volumes this means the total disk space used is more than the actual assigned volume size. For example a 1TB volume might then show 1.48 TB for total volume usage with Replay.
By including the replay size in capacity this makes the stat useless. Has anyone else seen this with Compellent?
