Hi, I am using the windows agent for AppInsight IIS, but I also need to monitor TCP components on the same server. Will there be an issue as the component needs WMI. Hopefully this makes sense. Thanks.
If you're referring to checking if a TCP port is up, can do that with no creds so should be fine, quick rebuild if you needed to
Thanks for the reply, I am specifically referring to TCPv4 / v6 and the TCPIP Diagnostic component monitors. The v4 and v6 are labeled as WMI based. But they still show data even with the node being polled via agent. I should have put that in the question... my apologies.
Any problem remaining?
