I need this for staying safe, when someone change the firmware on a device I want to get an Alarm & Mail
Thanks and greets
Hah - I hadn't even spotted that here is an out of the box alert.
If looking for the SWQL behind that creates that alert then simply click the little down facing arrow and then click on Show SWQL.
Which in this case gives:
So we do something for HA on Fortinet Firewalls that looks at a specific object (a custom poller as it happens) and if the state has changed then the alarm triggers.So like a lot of our alerts, this trigger is evaluated every minute and the condition must exist for 2m. The condition is basically checking to see if the CustomPoller state is different than it was in the the last 10minutes. I had help with crafting this SWQL as it was beyond me, but pretty sure the History.Statuses>1 just means is it different than last time I checked.I'm thinking you could just adapt this to look at the IOS Version table or similar one of choiceAnyway, the SWQL for this is:
SELECT CustomPollerAssignmentOnNode.Uri, CustomPollerAssignmentOnNode.DisplayName FROM Orion.NPM.CustomPollerAssignmentOnNode AS CustomPollerAssignmentOnNodeINNER JOIN(SELECTCustomPollerAssignmentID, Count(DISTINCT RawStatus) AS StatusesFROM Orion.NPM.CustomPollerStatisticsWHEREDatetime>Addminute(-30,GETUTCDATE())GROUP BY CustomPollerAssignmentID) AS HistoryON CustomPollerAssignmentOnNode.CustomPollerAssignmentID=History.CustomPollerAssignmentIDWHERECustomPollerAssignmentOnNode.CustomPollername='Fortigate_HA_State_Change'AND History.Statuses>1
HTH.
thanks for your reply. What I am looking for is an alert like this, coming out-of-the-box:
If someone know which SQL-query is behind "IOS Version has changed" or from another alert "IOS Image Family Change", I could adapt this alert.
greets
OMG You saved my day!
I am really looking for this and did not find it... I know this when I build a report, but there it is:
In the meantime I found this query, the "WhyReload" Entry is interesting too.
SELECT TOP 1000 ChassisID, ChassisSerialNumberString, NvRAMUsed, RomVersion, RomSysVersion, ProcessorRAM, RomID, WhyReload, LastDiscovery, FirstDiscovery, MissingFROM NCM.CiscoChassis
I will try to find a way for the other Vendor's - If I am succesfull, I will share it here.
