WIP
Need more real world examples, but is designed to show where the cores on the guest are running at less than 50% the speed of the cores on the host.
For some boxes this will be fine, for SQL Server's it certainly won't be
Have added in a percentage of cpu use as a filter because I believe the effective speed is an averaged value. Low cpu usage will artificially deflate that number if that is the case.
