Returns the SentryOne Monitoring Service(s) that is offline or not longer in use. This condition only works when two or more monitoring services are used.
If a SentryOne Monitoring Service is no longer connecting to the SentryOne Database and updating its HeartBeat for more than 3 minutes, the alert will evalute TRUE.
If a Monitoring Service is no longer in use, you may remove it from the SentryOne application by using the Client, expanding the correct Site, highlighting the no longer in use Monitoring Service and delete it.
It can be deleted with either the DELETE key or a right-click on the service name.
