This change template configures the NetFlow target on Cisco IOS Devices to Orion using Flexible NetFlow.
UPDATE: There were a few invalid characters at the end of the original file. It's since been updated with a replacement. If this doesn't work, then download the file, edit out the stuff at the bottom (the last character should be a curly brace in the first position) and then import manually into Config Change Templates.
