You can upload and download configuration using SSH just eter appropriate login name and password in the node properties page. Make suyre you disable the "Enable Level" and password. When downloading the config, it will pull two lines that need removed - the first line (| didsplay set) and the last line ({master:0}[edit]). You can upload the confis without any issues. If you review the session traces using a downloaded config you find an error in the session traces concerning the frst and last lines of the config file. I will contact Solarwinds to see if there is resolution to this issue. This device template may work with EX3200 series switches or other Juniper products running JUNOS OS.
