Allows you to get a config backup. It does a “get system summary” command. This output is not ideal as it doesn’t
include all the config but is better than nothing. “get config commands” is a better output but
unfortunately how it formats the output it confuses NCM and doesn’t work. That
is, the output includes the prompt characters (“->”) so that it confuses NCM
and thinks the command is done running when it is not. Set "Request Configs Using" and "transfer configs using" to telnet/ssh (CLI).
