The Cisco SF300 Small Business managed LAN switch is a menu-based switch so the template has to provide the username and password instead of the NCM configuration providing it to the switch. This template enables configuration download from the LAN switch to NCM using TFTP. To make this work, replace the "[username]" and "[password]" entries on the PreCommand statements with the user name and password to the switch without braces. It should look like this;
<Command Name="PreCommand" Value="joeuser${DownArrow}"/>
<Command Name="PreCommand" Value="joespswd${ENTER}"/>
In the NCM configuration for the switch, in the Login Information section, clear the Username and Password fields, and set Enable to <No Enable Login>.
Set the Template to this template and you're ready to go.
