This template will pull the running configuration from a Cisco Small Business swtich through Telnet. To issues commands to it, it is recomended to issue them from a Job configuration. For best results navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolarWinds.Net\Configuration Manager\Settings and add a string value called 'Transfer Attempts Count' and give it a value of 10. This will help with failures when retrieving the configuration. You may have to select to correct device template for that switch. I have tested this on SGW2048 and the SWG2000P models
