ACS 5.X device type definition.
Tested on ACS 5.2, but should be pretty easy to modify for other versions if they are different.
Note: most of the ACS application is not backed up via command line but is done via repository from GUI. This only allows you to save the bare metal config (SNMP, IP, repository, usernames, etc).
