Network Performance Monitor
3Com CPU
3Com CPU & Memory
6509 Temp Table
ABB UPS details
ANIRA ATT VPN Gateway 8300
AOS6_CPU_Memory
AOS8_Cpu_Memory
AP ID for Meru AP
APC Automatic Transfer Switch Oids
APC Metered PDU - AMPs
APC Metered PDU - Amperage
APC NetworkAIR
APC Power Bar
APC Power strip sockets
APC Smart PDU monitors
APC SmartUPS Universal Device Pollers
APC Switched Rack PDU (AP8000)
APC Temperature Sensors
APC UPS PDU Outlet Status
APC rPDU
APRESIA_AEOS
APRESIA_AMIOS
ARP Table
ASA Number of Active Sessions
ASA VPN Sessions, Durations, and graph of current RAS Client connections
ASA nr of top-curr connections
ATS PDU
ATS power socket
AVTECH RoomAlert4eTemps
AVTech
AVtech TemPageR
Active IPSec Tunnels
Active IPSec Tunnels for Cisco ASA
Active IPsec IKE Tunnels
Active Wireless Clients
Adtran CPU
Aerohive
Airedale - Carel PCOWeb Interface
Alcatel Nokia Node Details Poller
Alcatel Nokia Node Details Poller v2
Alcatel Omniswitch CPU and Memory
Alert in Development
Allied Telesis
Allied Telesis - Alliedware
Allied-Telesis
ApresiaLight
Arista Node Details
Aruba
Aruba ClearPass CPPM CPU & Mem Poller
Aruba Wireless Controller Client Stats
Aruba iAP( Instant AP) UnDP templates
Aruba/HP Switches
Asterisk IAX Channels
Avaya
Avaya ERS CPU
Avaya ERS CPU
Avaya ERS CPU
Avaya ERS CPU
BGP Peer Info
BGP Updates - Cisco
BOSCH CCTV
Barracuda ADC
Barracuda SPAM Firewall Queues
Barracuda Web Filter Universal Device Poller
Blue Coat ProxySG
BlueCoat CAS Universal Device Poller
BlueCoat CPU and Memory
Bluecoat MEMORY Pressure,CPU and DISK Utilization
BridgeWave Wireless Link
Bridgewave_Link_Level
Brocade CPU & Memory ICX7250-24
Brocade Fiber Channel
Brocade ICX Switch
Brocade ICX Switch
Brocade MLXe Router
Brocade MLXe Router
Brocade VDX 6740
Brocade VDX 6940
Brocade VDX 6940
Brocade VDX Switch
Buffalo TeraStation Node Details Poller
Buffalo TeraStation Pollers
C-Series Hardware health
CISCO CRC Poller Example
CITRIX NetScaler - CPU and Memory
CMTS Pollers
CPU and Memory utilization poller for H3C HPE HSR6602-XG routers
CPU_Manufacturer
CUBE (Cisco Unified Border Element) UnDPs
Call Admission Control statistics on an AP basis from Meru
Call admission control statistics on a BSSID basis for Meru wireless
Cambium 650 PTP RX Level
Cambium Networks PTP
Cambium ePMP
Cat 4500 module inventory
Cat 6500/4000 Inventory (Includes Slot, serial, model and firmware version)
Catalyst 9500-48Y4C
CellularPollers_CardActivationStatus
CellularPollers_CardESN
CellularPollers_CardMDN-CellNumber
CellularPollers_CurrentRSSI
Check Point FW-1 UnDP
CheckPoint Firewalls Universal Device Pollers - v2
Checkpoint Firewalls Universal Device Pollers
Checkpoint Multiple CPU UnDP
Checkpoint Number of AcceptedPackets
Checkpoint Number of Dropped Packets
Checkpoint Number of Sessions
Chloride UPS Amperage
CienaDWDM
Cisco - Last Reload Reason
Cisco 2811/6509 Temp
Cisco 3750 Stack
Cisco 3750 Stack Power Consumption Per switch
Cisco 6500 Backplane Utilization
Cisco 6500 Fabric Utilization
Cisco 897 ISR Node Details
Cisco 9200
Cisco ACE - Current Conn, Total and status
Cisco ARP Table
Cisco ASA 9.6 VPN Pollers
Cisco ASA Active VPN Connections
Cisco ASA Connections
Cisco ASA Current Remote Access VPN Connections
Cisco ASA Failover UNDP
Cisco ASA Failover status
Cisco ASA Global Connections poller
Cisco ASA Hardware Health & failover status monitoring
Cisco ASA SSL Tunnels
Cisco ASA Serial Number
Cisco ASA Serial Number w/modules
Cisco ASA WebVPN Tunnels
Cisco ASAv
Cisco ASR / ISR
Cisco ASR 1001-HX Node Details
Cisco ASR 1001-X Node Details
Cisco ASR 1002-X, 1002-HX Node Details
Cisco ASR 1006-X Node Details
Cisco ASR 1009-X Node Details
Cisco ASR Chassis Throughput
Cisco ASR Devices
Cisco ASR9K
Cisco ASR9K
Cisco BGP
Cisco BGP Status Table
Cisco BGP-Hip23
Cisco Buffer Tables
Cisco CDP
Cisco CDP Neighbors Table
Cisco CDP-vhSMw
Cisco CRC Errors
Cisco CSM Real Connections per server
Cisco CSM Virtual Server Pollers
Cisco CSS
Cisco CSS 11506 CSS Monitoring
Cisco Call Manager Information
Cisco Cat / IE / IR 8K-9K and IE 3K Series Device Details v1.11
Cisco Catalyst 1000
Cisco Catalyst 4500 PoE pollers
Cisco Catalyst 8300
Cisco Catalyst 8500
Cisco Catalyst 93xx Stack
Cisco Catalyst C9300
Cisco Device Serial Number
Cisco Duplex Status UnDP if standard doesn't work
Cisco FXOS Firepower UnDP version 1
Cisco Fan Status Table
Cisco FirePower
Cisco FirePower Hardware
Cisco Flash Free Partition Space
Cisco Flash Memory
Cisco GSS
Cisco HSRP
Cisco HSRP-dNjrE
Cisco IMC & UCS (APIC,ISE/SNS,ND,UCM) Based Device Details
Cisco IOS-XE Memory
Cisco IP Accounting
Cisco ISR 4000
Cisco ISR 4300 Node Details
Cisco ISR 4321 CPU
Cisco ISR ASR CPU Memory
Cisco ISR percentages Devices
Cisco Input/Output Queue Drops
Cisco Interface Collisions
Cisco Interface Trunk Status
Cisco IronPort
Cisco IronPort
Cisco LWAPP Pollers
Cisco License Management Poller
Cisco License State UnDP
Cisco License Type UnDP
Cisco License UnDP
Cisco Line Status Protocol
Cisco NCS Node Details
Cisco NCS5501 CPU
Cisco Nexus 9396PX Node Details
Cisco Nexus 9396TX Node Details
Cisco Nexus CPU & Memory Universal Device Poller Configuration
Cisco OSFP Interface state
Cisco OSFP Neighbor
Cisco OSPF
Cisco OSPF Interface States
Cisco Power Supply Status Table
Cisco Routing Table
Cisco SmB Switch (SG/SF) - Node Details
Cisco Small Business Series
Cisco Small Business Switch - Pollers for Boot, Image, and Hardware versions
Cisco Sup720 UnDP
Cisco Temperature State Table
Cisco Temperature as Percent of Threshold
Cisco Temperature in Celcius
Cisco UCS Active Hardware Alerts in Solarwinds
Cisco UCS Chassis Inventory with Status
Cisco UCS Chassis Slot Information
Cisco UCS Disk Drive Status
Cisco VG320 Node Details
Cisco VG350 Node Details
Cisco VSS Pollers
Cisco WAAS connections
Cisco WLC 5520 - Node Details
Cisco WLC CPU and Memory
Cisco WSA
Cisco Wireless Controller 5500 Power Supply Status Pollers ~ CiscoWireless5500-PowerSupply.UnDP
Cisco Wireless LAN Controller Details
Cisco additional port status information - by node
Cisco speed/duplex counters (For SQL report).
CiscoACEPoller
CiscoADSL
CiscoWAAS
Cisco_2960_Fan_Status
Citrix NetScaler UnDP
Citrix SD-WAN
CloudGenix UnDPs
Cloudgenix ion 2000
Custom Palo Alto UnDP
Custom Pollers for CPU and Memory Utilization of Fortigate devices
Cyber Power Systems
CyberPowerUPS
DELL MXL 10/40GbE
Dahua DVRs
Dell 5400 switch temperature monitor
Dell CT-SC Series Storage Array
Dell Chassis Information
Dell Chassis Slot Info
Dell Disk States
Dell Hardware Monitoring-9cy.l
Dell PowerConnect 28xx (CPU ONLY)
Dell S4820T (9.11)
Dell Server - various pollers
Dell Server pollers
Dell Storage Pollers
Dell Switch - Node Details
Dell Switch CPU and Memory
Dell Switch Node Details
Dell Temperature Probe and Transform UNDP
Dell UPS Device Pollers for OID 1.3.6.1.4.1.674.10902...
Dell iDRAC Node Details
Dell iDRAC Universal Device Pollers
Device Pollers
Eaton
Eaton 9PX 3000 UnDP
Eaton EPDU Node Details
Eaton UPS
Eaton UPS - Node Details
Eaton UPS Custom Poller
Eltek Rectifier
Eltek Rectifier-jIUg3
Emerson Network Power Liebert UPS Device Poller
Emerson/Liebert UPS Monitoring
Exide UPS
Extreme
Extreme CPU and Memory
Extreme ExtremeWare Switch CPU
Extreme Switch Serial Number
Extreme Switch Temperature
F5 - Collection of Mibs (v9 of F5 code or higher)
F5 - vCMP
F5 BIG-IP (v4.5) Pool and Virtual Server Info
F5 Big IP Chassis Fan Poller
F5 Big IP Chassis Power Supply Status Poller
F5 BigIP - Current Connection Tabular Poller
F5 BigIP 11.1+ config sync state
F5 CPU and Memory Utilization
F5 CPU& Memory
F5 CPU& Memory
F5 Config Sync Status
F5 Loadbalancer
F5 Pollers
F5_CPU_Memory
Fake_poller_for_testing_node_details
Force10_Throttles
Forcepoint NGFW
FortiADC
FortiAP 221E
FortiAP 224E
FortiAP 231F
FortiAP 431F
FortiAP 831F
FortiAnalyzer CPU and Memory
FortiAnalyzer VM64
FortiAuthenticator VM64
FortiCache VM64
FortiGate HA Info
FortiGate Memory and CPU Utilization-O8YRF
FortiGate Version-_zpvi
FortiMail
FortiMail Info
FortiManager VM64
FortiSandbox VM
FortiSwitch CPU and Memory
FortiWeb VM
FortiWeb VM
Fortigate
Fortigate 1000D
Fortigate 100E
Fortigate 100E
Fortigate 100F
Fortigate 100F
Fortigate 200E
Fortigate 200F
Fortigate 200F
Fortigate 2200E
Fortigate 300E
Fortigate 600E
Fortigate 60E
Fortigate 60E
Fortigate 60F
Fortigate 60F
Fortigate 60F
Fortigate CPU
Fortigate CPU Core Polling
Fortigate CPU/MEM
Fortigate E
Fortigate E
Fortigate Firewalls
Fortigate IPSec Interface - UnDP IPSEC Creation
Fortigate Node Details
Fortigate-Serial
Fortimail-CPU
Fortimanager CPU and Memory
Fortinet Fortigate - Node Details
Fortinet Node Poller
Fortiswitch 1024D
Fortiswitch 108F-FPOE
Fortiswitch 124E-FPOE
Fortiswitch 124E-POE
Fortiswitch 148E-POE
Fortiswitch 224D-FPOE
Fortiswitch 224E
Fortiswitch 248E-FPOE
Fortiswitch 248E-POE
Fortiswitch 448D-FPOE
Fortiswitch 448E-FPOE
Fotrousi Electronics Rectifier-4850-V5
Foundry ServerIron Real Connections Monitor
GE UPS
Geist Environment Monitors
Guide: Add the ability to see historical client count data for Cisco Wireless Controllers
HP Blade Center C7000 BladeSlotInfo.UnDP
HP C7000 Blade Slot Info
HP Drive Status
HP Onboard Administrator
HP Page counts and Toner Level for 4250dtn printers
HP Physical Disk and Logical Disk Configuration and Status
HP Pollers for Hardware Summary Report
HP Procurve CPU and Memory
HP Proliant Server Custom Pollers
HP Proliant pollers
HP Proliant pollers-RVRSr
HP Server Temp Pollers
HP iLO and OA Firmware versions
HP procurve
HP-Aruba Node Details
HP-Aruba switch node details (software versions) with Static HPE vendor
HP-Aruba switches Node Details (software versions)
HP-OfficeJet-InkLevel
HPE 1920
HPE 1920S 24G 2SFP PoE (370W) JL385A
HPE 5500-HI
HPE Aruba 6300M Switch CPU and Memory Poller
HPE Aruba 6300M Switch Details Poller
HPE Aruba 6300M Switch Details Poller v2.0
HPE FlexNEtwork 5510
HPUX 11.31 Custom Pollers (CPU, Memory, Filesystem)
HP_Proliant_Custom_Pollers
How to monitor old ups device with serial port
Huawei Fat AP
Huawei WLC Cpu and Memory
Huawei WLC-1
Huawei_CE6881
Hughes HN9260 Satellite Router
ICT Distribution Panel Node Details
ICX Stack Details
ICX stack pwr fan temp Poller
ISE Details
IT Watchdog UnDP
IT Watchdogs - Weather Goose II
IndigoVision BX420-4MP
IndigoVision BX720-12MP
InfoBlox DHCP Statistic UNDP
Infoblox CPU IP_CPU
Infoblox Details
Infoblox Details
Installed Software Poller
Intel IPS Engines
Interface Discards - Cisco and Juniper
Interface index for Meru AP
IronPort
Isilon OneFS
Jacarta Temperature Sensor
Jacarta iMeter
Juniper - Red Alarm Count
Juniper - Yellow Alarm Count
Juniper CPU
Juniper CPU
Juniper EX Switches
Juniper EX4200 CPU and Memory
Juniper EX4200 Temperature
Juniper IVE
Juniper IVE - SA Series CPU/Mem/Disk/Users
Juniper J2320
Juniper MX Switches
Juniper Netscreen
Juniper Netscreen Node Poller
Juniper Netscreen VPN Tunnel
Juniper SA / MAG SSL VPN
Juniper SRX1400 v2
Juniper SRX240 CPU
Juniper SRX240 CPU, Memory, and Flow
Juniper-IVE
Juniper/Netscreen VPN Status (bytesIn, bytesOut, P1, P2, Gateway IP details)
Junos (EX) Temp Poller and Alert
Just Test
LLDP Remote Neighbors and port description.
Lantronix SLC Port Names
Liebert CRAC, Computer Room Air Conditioning UDP
Linux CPU Load Average and Memory
Linux Disk IOPS
Linux System Uptime
LinuxMemoryUNDP
Load Average
Lucent LCS Telica, Inc.
Lucent LCS poller
MGE\Eaton UPS UnDP's
MINUTEMAN SNMP-NV6
MINUTEMAN SNMP-NV6/SNMP-NET.UnDP
MS DHCP Scope Status
McAfee Sidewinder
Mellanox: Node Details
Meraki v2
Merlin Gerin Comet 125
Meru AP interface index
Meru Access Point Name
Meru statistics poller equivalent to 'show statistics station-per-ap' command
MikroTik
Mikrotik
Mikrotik
Minuteman UPS
Minuteman UPS SNMP-NET
Mitel 3300 Status UDNP
Monitor Dell Equallogic iSCSI SAN storage with UDPs (Universal Device Poller)
Monitor the status of Checkpoint VPN site-to-site tunnels
Monitor the system health of Riverbed appliance
Monitoring Cisco CBWFQ bandwidth utilization
Monitors total WATTS consumed of a Cisco stackable (3560, 3750,etc) PoE Switch
MultiCPU_CustomPoller
Multiple APC NetBotz Environment Monitor
Multiple CPU Cores
My Juniper UnDPs (EX, SRX, SA, ScreenOS)
My basic Palo Alto UnDP
N3K-C3548P
N9K-C9508
NGC_Dell_6200
NX9500
Net-SNMP
NetApp Disk Health
NetApp Health Stats
NetApp Volume Percent Utilization in KB
NetApp Volume Usage-Detailed
NetAppStats
NetBotz UnDP
NetScaler CPU/RAM
NetScaler Universal Device Pollers (UnDP)
Netapp Filer universal poller
Netbotz_Fahr_Temp
Netman or RFC1628 UPS UnDP
Networking: F5 BIG-IP Multi CPU
Nexus - CPU/Memory
Nexus Device Tables . UnDP
NimbleStorage
Noise level on Meru AP
Nokia Checkpoint IPSO
Nortel / Avaya ERS (8300/8600) PSU, Fan and Card poller
Nortel 8600 MLT/SMLT Pollers
Nortel BayStack 55xx PoE Consumption Pollers
Nortel-Avaya ERS Switch Temperature Poller
OAW CPU
OSPF Neighbors
OTV-state
Occam_Firmware_Version
Onechy_CpuMemory_Test01
Opengear Console Server Extended Pollers
Opengear Console Server Pollers
Packeteer Hardware UDP
Palo Alto Active VPN Tunnels UnDP
Palo Alto Firewall
Palo Alto Firewall Session UnDP
Palo Alto HA Firewall Failover Poller
Palo Alto Networks- Global Protect
Palo Alto Node Details
Palo Alto Percent Session Table Utilization
PaloAltoPollers
Palo_alto_active_sessions
Poller for Meru command 'show statistic top10-station-talker'
Pollers for Current, Power, Voltage, Temperature on WTI Switched PDU
Polling of ISDN channels on routers
Port Duplex Status
PowerConnect-5524 DELL
ProCUrveMSM-KTB01
ProCurve/Colubris Wireless Controller
Promise Array Drive Status Pollers
Pulse Connect Secure PSA7000-V Node Details
QLogic SANbox Port Tables
RAD - CPU and Memory
RSA SecurID
RSA SecurID
RX count on Meru AP
Raisecom ISCOM Switch CPU and Memory
RedHatCluster
RedHatLDAP
Riverbed CMC
Riverbed Interceptor
Riverbed Mobile Controller
Riverbed SteelHead CX
Riverbed SteelHead EX
Riverbed Steelhead Legacy and CX Node Details
Riverbed Steelhead Universal Device Poller v1
Riverbed UnDPs
RiverbedHealthStatus
RiverbedOptimisedConnections
Ross IPv6 test of F5
Route Table Size - Universal
RouterOS
Ruckus Client count
Ruckus ZoneDirector 1120
Ruckus_WAP
SDWAN Remote Site CPU and Memory Utilization
SL8500 Tape Library
SOLIDServer BIND Pollers
Satcom Master AD Server
Siemens HiPath 3xxx/5xxx
Silver Peak UnDP
SilverPeak UnDP With Alarm Table
Snap Mirror Relationship
Socomec-UPS
SofaWare Safe@Office & Check Point UTM-Edge Appliance UnDP
SonicWall Firewall
Sonicwall CPU/MEM
Sonicwall Details
Sonicwall NSA CPU
Spanning Tree Port State
Stulz UnDP
Synology
Synology Inc. Universal Device Poller
Synology NAS Node Details
Synology Network Attached Storage (NAS)
Telco T-Marc 280 CPU and Memory
Test CPU poller
Test CPU poller
TippingPoint IDP Temperature
TippingPoint IPS CPU
TippingPoint IPS CPU & Memory
TippingPoint UDP - CPU, NPtier, Fall-back, etc..
Trango Wireless
Transmode TM-3000 DWDM and Packet Optical
Ubiquiti NanoBeam 5AC 16
Ubiquiti NanoBeam 5AC Gen2
Ubiquiti Networks, Inc.
Ubiquiti Vendor Name
Ubiquiti Wireless APs
UnDP NTP poller for ntp peer and status
UnDP PDUs Tripp Lite
UnDP for Cisco Thin Access Points via WLC
UnDP for pulling the serial numbers off of Cisco 3000 Series VPN Concentrators
UnDP for pulling the serial numbers off of Cisco CSS11503 devices
UnDP for pulling the serial numbers off of Riverbed Accelerators
UnDP for pulling the serial numbers off of some PIX and ASA firewalls
UnDPs for printer toner, page count, and supply kit levels
VLAN Information for Alcatel Stacked switches
VLAN Table
VMware Guests
VSP CPU
Vertiv Emerson Liebert UPS Battery Environmentals
Viptela_CPU
Websense WCG
Windows Disk IO Using SNMP Informant
Wireless_Rogue_AP_Detection
YAMAHA RTX CPU and Memory
Zebra - AP7522 - CPU
Zebra - AP7522 - CPU and Memory
ace_probes
bluecat_dhcpscopes_status
ciscoEnvMonTemperature
cpmActiveDSOs
goroh_NodeDetails-1
goroh_lithium_test
hpicfSensorStatus
hrSystemUptime
ifInOctets
ifIndex
infoblox_be1
linuxatemyram
pfSense
poller for Meru command 'show statistics top10-ap-problem
poller for Meru command 'show statistics top10-ap-talker
sraOverallSystemStatus
stat
statistic on bytes transmitted on Meru AP
statistic on loss percentage on Meru AP
statistic on throughput on a Meru AP
statistic poller for failed frame transmission count on a Meru AP
test_ifType
vmWare VeloCloud
vmWare VeloCloud
Fortigate 60F
UploadedFile.xml
Fortigate 60F Identification
