<!-- If this device has a config larger than 999 lines, then the use of the MORE command might be needed -->
<!-- However I wouldn't recommend using the more command unless necessary -->
<!-- <Command Name="MORE" Value="lines"/> -->
<Configuration-Management Device="Gigamon" SystemOID=" 1.3.6.1.4.1.26866">
<Commands>
<Command Name="RESET" Value="terminal length 999"/>
<Command Name="Reboot" Value="reload${CRLF}y${CRLF}y"/>
<Command Name="EnterConfigMode" Value="configure terminal"/>
<Command Name="ExitConfigMode" Value="end"/>
<Command Name="Startup" Value="startup"/>
<Command Name="Running" Value="run"/>
<Command Name="DownloadConfig" Value="show ${ConfigType}"/>
<Command Name="UploadConfig" Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}"/>
<Command Name="Version" Value="show version"/>
</Commands>
</Configuration-Management>
