This looks for various SNMPv3 lines in the config, then provides a way to add them if they are not already there.
milstateit@mil.wa.gov had asked about a simple way to add his SNMPv3 settings to his device configs.
Scripting noob question
This report was made simply as an example, to show a different way to complete a task.
This simple compliance report looks through the last running config, for all devices, for an entire block of code:
snmp-server group "groupname" v3 priv read "readview" write "writeview"
snmp-server user "user" "groupname" v3 auth md5 "password" priv aes 256 "password"
snmp-server view "readview" iso included
snmp-server view "writeview" iso included
snmp-server host "IP" version 3 priv "user"
snmp-server enable traps
If this block of config is not found, the report will off to add it by doing the following:
configure terminal
end
copy run start
-Will
