Identify Cisco ASR 1002-X, 1002-HX, 1002-XC Chassis
This poller will correctly populate the Machine Type field for a Cisco ASR 1002-X, 1002-HX, 1002-XC chassis as such rather than as simply "Cisco". This poller will also populate the software image filename.
NPM 11.5.3 does correctly identify the MachineType of a ASR 1002-X chassis using the stock poller, but it does not populate the boot image filename.
