This is actually a very repetitive UnDP, specifically for APC NetBotz devices. This could be helpful when you have many temperature monitors plugged into the same device and need to create an individual UnDP for each one, this has the original value, and a transform into Fahrenheit. If node abc has 2 tempmons, and node xyz has 2 tempmons as well, they both are the same OID so one UnDP is less than ideal unless it can be correlated to the Location or Name OID somehow -- requires some SQL knowledge but possible. Hope this may be helpful for others.
