Returning the Favour..
Attached is a Collection of UDP's for monitoring an Airedale CRAC fitted with a PCOWeb Interface, manufactured by Carel. Took a bit of piecing together this one and will depend on which sensor is wired into which Digital and Analogue ports, you might want to check it's reporting corectly for your CRAC.
For completeness this is used on a V31X2
