This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Installation SolarWorlds locally
At one point i get following error when installing the software on my local machine. too try it. it was the 5 time i tried to install but with different error messages. can you help out?
Fehlgeschlagen: Invalid Orion Core Configuration value. The registry value at HKLM\SOFTWARE\SolarWinds\Orion\Core\Configuration is not valid.
i searched von the value in the registry but there is no .../SolarWinds/Orion/Core/Configuration entry its missing can i can't even add that entry because there is no solar wolrds folder
any suggestions to help me install this software soon.
