This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
"Could not get any response" thru Postman when connecting to Solarwinds
Hello,
I am going crazy trying to figure out why Postman can't connect to Solarwinds.  I get the following:
I've tried manually running the same URL thru Chrome and I'm returned the results successfully.  I've checked the suggestions in the error and have verified there are no issues.  (Turned off SSL certificate verification, we don't use a proxy, request timeouts are good as the GET fails immediately. : (
I'm going thru the guide I found online to set this up, there is a part where it states to select the "Update Request" button on the Basic Auth section, I don't see this button anywhere.  I do see the Headers was updated successfully though.
https://loop1.com/swblog/using-the-rest-api-to-get-the-most-out-of-solarwinds-part-1/
Thank you for any help possible, much appreciated
Tom
