Every year seems to be met with an optimistic glow of it being the “year of the desktop”. By that, I mean that a large shift will push virtual desktop infrastructure (VDI) into the lime light. Virtualizing a desktop is pretty easy, and lots of products out in the field can wrap a desktop OS inside of a hypervisor and provide brokerage. This is often the sticky spot, too, as the goal shouldn't be to simply “make your desktops virtual” but to completely shift the delivery method to embrace an improved desktop model. I've seen some deployments fail because a traditional model of patching desktops, doing antivirus scans, and pushing out software were laid on top of a virtual infrastructure and caused crippling failure.
So let’s assume you have provided the hardware infrastructure to deliver the performance needed for a virtual desktop. Again, not terribly difficult to do with today’s modern technology. The question then becomes – how do you deliver the applications? Recall that the entire point of a desktop is to provide a platform in which the user can connect with their software. Is the answer thin apps, streaming apps, or continue with thick installed apps? I tend to think this will be a combination of the above.
Have you embarked on the journey towards providing virtual desktops, or even thin / streaming applications, to your clients or users? Care to share your experience and opinion?
What challenge have you met that had to be conquered, compromised on, or caused your project to halt or shift in a new direction?
Reply to this post and earn 1 entry to win an iPod Nano!
