Hell0
I have a task to get and report on the status of multiple VCenter's located at different sites. For example, site1 may have three VCentre's:
>> imaginiativeName0
>> imaginativeName1
>> imaginativeName2
If the status of all three is OK, or Up, the overall status is OK. If the status is Warning, then the overall status should also be Warning. However, the status should only be critical when all Vcenter's have a critical status
I am using the following query to grab the information:
