2 Replies Latest reply on Nov 22, 2013 9:37 AM by james.w.troy
    PS script for SAM stops working after v6 installed
    james.w.troy
      Dear Sir or Madam -
      We wrote a Powershell script that uses the SWISsnapin to add or remove nodes in SAM.  It worked fine with SAM versions 5.2 and 5.5.
      After upgrading to SAM version 6.0, nodes that are added using our script cannot be viewed on the "Manage Nodes" page.
      A search by node name finds the nodes, but when viewing the "Node Details" page, the "Node Details" pane is empty.
      There must be some new fields or settings in the database that we're supposed to set when adding a node.
      The SDK version we've installed is 1.5.
      Please advise.   Thank you.
      James Troy
