Hello Everyone,
Is there any way to unmanage and re-manage multiple nodes? May be from the tool or by using powershell script.
Abhishek
Hello Everyone,
Abhishek
Hi
Solarwinds Unmanage Utility is already available.
Please refer the below link:-
Regards
Mohit
Thanks Guys for all your Help..
Yes, I'm aware of the above options which you provided. I feel this becomes hard for me when i have to unmanage/re-manage more 10 nodes at a time. I need to go search for them if i have 100's of nodes. So i'm looking for any other options which makes this little simpler
Here is a good amount of information using the SolarWinds SDK https://thwack.solarwinds.com/thread/62160
you may be using custom property and can identify the nodes using custom property ,from manage nodes page you can select them based on custom property and unmanage/remanage as required.
Save this as .ps1 and run it. This will use your AD credentials to authenticate to your Orion server and unmanage a node named NODEYOUWANTTOUNMANAGE for 10 minutes from now.
Add-PSSnapin SwisSnapin
$swis = Connect-Swis -host YOURORIONSERVER -Trusted
$nodeid = Get-SwisData $swis "SELECT NodeID FROM Orion.Nodes WHERE SysName LIKE 'NODEYOUWANTTOUNMANAGE'"
$now =[DateTime ]:: Now
$later =$now.AddMinutes(10)
Invoke-SwisVerb $swis Orion.Nodes Unmanage @("N: $nodeid ", $now ,$later , "false")
Thank You Prashant. Can you give me an example how can we create the custom property for this scenario.
