Hi all,
I have a slight challenge within my environment that might have a simple solution... I need to create various groups for nodes that are separated via building or location but cannot find a simple way of creating multiples other than one at a time (1-by-1).
Within the setup,I have a custom property on all the nodes that defines the location of the device. Other than 1-by-1 group builder, is there a method that can be used to create multiple groups by passing dynamic variables? ... Please see the basic example below of what I am trying to achieve:
Top Level Group - Dynamic Query Selected by customer (The top-level group has been created)
Sub Group - (Location 1)
Nodes in this group require a dynamic query for the "Location A"
Sub Group - (Location 2)
Nodes in this group require a dynamic query for the "Location B"
Sub Group - (Location 3)
Nodes in this group require a dynamic query for the "Location C"
... and so forth ...
I am happy to create all groups separately if there is no other method. However, I have a minimum list of 50 + locations that I would like to separate into groups, it will become time consuming very quickly.
If there is another method via scripting that would work for the creation of the multiple sub-groups by using dynamic, please walk me through how I can set this up as it will save me a lot of setup time. (I do have some knowledge and experience with PowerShell scripting, but haven't yet looked if I can interact directly or apply the correct variables).
Thanks in advance,
Tom
