cancel
Showing results for
Search instead for
Did you mean:
Alert condition based on time between warning and critical threshold
I've got a requirement wherin if Critical threshold have reached after 120 min of warning threshold, an alert should be generated. This is to notify incase there is a sudden growth that degrades the performance.
Ex - We already have 2 separate alerts for warning and critical threshold that generates respective alerts. Now there is a requirement of a 3rd alert which should only trigger if the warning is escalated to critical within 120 minutes for any device.
Thanks.
0 Kudos
mesverrum
Level 20
Re: Alert condition based on time between warning and critical threshold
That kind of logic can't be done in the alert GUI, would have to be a custom sql/swql alert condition.
0 Kudos
Thanks buddy. Would you be able to help me with the logic. I haven't worked much with complex SWQL queries.
0 Kudos
