cancel
Showing results for
Search instead for
Did you mean:
Script to Monitor number of directories (not files)
The sample script returns 1 if the number of directories within a specified path is
greater than the number of specified within the command.
If the difference is less than or equal to the specified number, the script will return a 0.
Sample Monitor Settings
For the following example, we will assume the following:
    Path: \\WebSrv1\dirs\
    Maximum directories allowed: 300
    Script Location: c:\ipmscripts\
For Windows 2000
  Executable Name: cscript.exe
  Directory: c:\winnt\system32\
  Command Line Parameters: dircount.vbs \\WebSrv1\dirs\ 300
  Startup Directory: c:\ipmscripts\
  Compare the Process Return Value = SELECTED
  Expected Return Value: 0
For Windows XP / 2003
  Directory: c:\windows\system32\
The sample script is not supported under any SolarWinds support program. The
sample scripts are provided AS IS without warranty of any kind.
Comments
it's helpful to use
Version history
Revision #:
1 of 1
Last update:
‎11-02-2011 12:00 AM
Updated by:
