cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
use http post in monitor
Hi folks,
Currently in the http or https monitor,  there is no way to specific the http method.  By default, it is using get.  Is there a way to force the monitor to do http post?
John
Tags (1)
0 Kudos
1 Reply
Level 13
Hello Sonic,
At this time ipMonitor can do GET and HEAD requests.  The ability to do POST requests is something that has been requested in the past and has been added to our Feature Request list for possible implementation within a future version.  Until such a feature is implemented, you would need to write a script which would perform the POST against your web site and then verify what is needed.  Once the script is written, trigger it using the External Process Monitor.
Sincerely,
Chris Foley - SolarWinds - Support Specialist
Support:  866.530.8040  |  Fax: 512.857.0125
network management simplified  |  solarwinds.com
0 Kudos
