cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 10
resource planning for ipMonitor: need guidance
I am an Orion user, but I have been talking to a net admin bud of mine who is considering SW products. I think that ipMonitor is a better fit for him due to network size and the fact that he does not need to keep historical data.
That said, I don't know enough about ipMonitor from a theory standpoint to be able to talk about server requirements (CPU speed and number, amount of RAM needed, drive space and configuration options, etc.) and other planning aspects that one should consider prior to purchasing and installing ipMonitor. For instance, should one be concerned about the effects of the number of configured monitors on server resources and network bandwidth?
Does SW have a guidance document that details that essential questions and issues that one should consider before installing and configuring ipMonitor?
Any help would be appreciated.
0 Kudos
Highlighted
Level 15
Re: resource planning for ipMonitor: need guidance
Here is a link to the FAQ:
http://www.solarwinds.com/products/ipmonitor/faq.aspx
This should address most of your questions.   There are also links for system requirements, as well as features, and an overview.
0 Kudos
Highlighted
Level 7
Thanks for the Great Question freeman!
We do have system requirements available in the Admin Guide and on our website.   Here is a link to our web page that describes these things.
http://www.solarwinds.com/products/ipmonitor/system_requirements.aspx
As for bandwidth consumption,  this is not a simple metric to calculate because every cleint uses the software uniquely in their own environment.  For example:  Someone using ipMonitor to test simple availability (ping) of 5000 nodes on their network will see significantly less network overhead then someone who is monitoring 300 SQL servers.   The amount of network traffic generated depends on monitor types.  Additionally, the more frequently these monitors are set to perform each test.   The default is 300 seconds between each test, but you can set it to be as aggressive as 1 second (however,  this is not recommended)
0 Kudos
Highlighted
Level 10
Thanks for the two replies. I have another question. Where (file name and location) does ipMonitor store the statistical data?
0 Kudos
Highlighted
Level 17
Under the DB temp directory (last 24hrs.)  and also DB store - in the installation directory.
0 Kudos
Highlighted
Level 10
I see some data files in these folders with TLOG and PLOG extensions. What, if anything, can open and read these files?
As far as data retention and deletion are concerned, does one simply need to delete these files at some arbitrary size limit? Or, is there a more formal procedure for maintaining these data files?
0 Kudos
Highlighted
Level 13
Hello Freemen,
Every file within the \dbstore\ directory contains the statistics for all monitors for a specific day.  In order to keep these files an unbelievably small size, they are written in a binary and proprietary format which cannot be read and understood by anything other than ipMonitor.  As you can store many years of statistics without requiring any significant drive space (unless you are running this on a computer made in 1999), the need for maintenance is simply not there.
Hope this answers your question.
Sincerely,
Chris Foley
0 Kudos
Highlighted
Level 7
Hi Chris,
I have some PLOG files that are old enough not to be required any more.  Can they just be deleted?
R.
Adam
0 Kudos
Highlighted
Level 13
Hi Adam,
I always recommend backing up first but yes, you can delete the older files at will.
Chris Foley
0 Kudos
Highlighted
Level 7
FYI - I'm not sure if this helps answer the original question, but I have 1200 monitors with most at 30 second polling (though some at 60 second) and I get a new 22MB PLOG file in dbstore each day.
ipMonitor handles the deletion of a PLOG file really well.  If you delete a PLOG file, the history for that day just disappears :).  I have not noticed any glitches in monitoring, reporting or anything else as the result of deleting the 30+ of these files that were collected by ipMonitor before it became one of the live production systems.
0 Kudos
