Hello...
I'm using the SOAP interface on ipmonitor 10.x, to create groups and monitors.
When I try to delete a monitor using soap (MonitorDel), the monitor is deleted from the parent group but when I use the ipmonitor server interface and do a search for the monitor I just deleted, the monitor shows up (i.e. it wasn't deleted from the server). I have to manually delete it using the server interface for it to be completely erased.
Has anyone had experience with this issue?
An even bigger problem is if I delete the parent group (using soap), it's child monitors no longer have a valid parent ID, and I can't find any way to erase them from the server.
thanks
jp
