I have a query with regards to the email alert
>> query for token Monitordownlength gave me 3.08 minutes when the alert was triggered.
i.e. This was the first email I received when the alert triggered which had the monitor length down time of 3.08 minutes. My query is that if the alert is triggered once the thresholds are met, then why is there delay in the email..
Or is the delay the calculation equal to the time taken to satisfy the threshold settings + 3.08 Minutes
Why is there a 3.08 minutes delay for the alert to generate the alert?
The settings are
Last-Value Threshold | ||
Max CPU Usage (%) | 90 | |
Short-Term Threshold (for smoothing out spikes) | ||
Max CPU Usage (%) | 60 | |
Sample size | 300 | secs |
With regards to the above setting is the alert email time = 5 minutes + 3.08 minutes???t i
Pasha
Checking...
Email alerts are generated like this:
1) any monitor does tests periodically.
2) there is a value (numeric field) indicating the number of monitor fails when alert is triggered.
3) alerts, assigned to a monitor, are executed one by one.
4) at the same time, they may get a delay in email because of email service queue
It would be helpful to see your logs and to know if you're getting the same delay with other alerts (say, appending text-file and see modification date of the file). I would recommend opening a support ticket.
-Craig
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
