cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 7
SmartMonitor Settings for Temperature and CPU Usage
Hi all
If I check the temperature and CPU usage boxes in the smartmonitor settings, there will be added about 15 monitors for the temperature and for every cpu core one monitor,
But I need only the ambient temperature and the overall cpu usage monitors for each device.
Is there a possibility to change those SmartMonitor settings?
0 Kudos
Highlighted
Product Manager
Product Manager
Re: SmartMonitor Settings for Temperature and CPU Usage
Checking...
0 Kudos
Highlighted
Product Manager
Product Manager
The SmartMonitor settings for CPU and Temperature are going to enable the more granular monitors as you described.  In other words, those settings aren't going to be flexible in terms of the monitors they enable.  However, you can disable monitors you don't care about after the discovery is done.  Not exactly the answer you're looking for, but that's how the SmartMonitor settings will be applied.
-Craig
0 Kudos
