I want to create a scheduled email report publisher which gives the network uptime of our critical infrastructure (namely servers and routers). To do this I figure I need to create a SmartGroup that includes only the ping monitors of these devices. That's because I don't want pesky bandwidth/disk/memory monitors that go "down" to affect the uptime stats.
I've started creating a SmartGroup as follows:
SmartGroup contains: Monitors
Start with: No Monitors
Add monitors where property Device Type matches regular expression \i(router|server)
Remove monitors where property Type matches regular expression [insert expression here]
This is where I need an expression that removes all monitors except 'ping' monitors. Does anyone know how to negate the expression \i(ping)? My searches on the topic have shown that regular expressions don't allow you to negate a whole word (only a single character class). I've tried a few alternative suggestions but none give the desired result.
Or does someone have a completely different way of achieving the same result?
Thanks - Simon
