Is there any way that Ipmonitor can detect the expiration date of an SSL certificate.
Waiting for ur replies
The https monitor will alert when the certificate expires because it can not create a secure conection to a server. We found this out the hard way when a certificate expired which we forgot about.
We are using v8.5, but I assume v9.x has the same functionality.
Hi faisal123,
The ability to monitor the expiration date on an SSL Certificate is currently a feature request which is being considered for a future version of ipMonitor. If you wish to be notified when this gets added, simply open a case using the following form and we can then link the case to the feature request:
http://www.solarwinds.com/support/ticket
Thank you
Chris Foley
