How do you prevent the diskspace monitor from sending alerts via email? I still need it to be monitored because I need to generate a report but can't have alert emails sent out.
I have approximately 500 devices anyway to do this super easy?
Solved! Go to Solution.
Hello Brink668,
Within the settings page for the Drive Space Monitors, set the "Maximum Alerts to Send" to 0 and/or "Accumulated failures per Alert" to 999999.
Hope this helps.
Sincerely,
Chris Foley
Hello Brink668,
Hope this helps.
Sincerely,
Chris Foley
Do I have to do this for each diskspace monitor?
Is there a way to set this as the default monitor settings?
You should be able to use the Mass Edit feature by which you can filter for the Drive Space Monitors group and specify the values Chris indicated for all Drive Space Monitors.
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
