cancel
Showing results for
Search instead for
Did you mean:
How to Monitor https monitor with TLS 1.1/1.2 protocol
Jump to solution
Hello All,
Good Afternoon!!
Dhyanesh here from IT company working as Sr. System Admin and handling IPMonitor all by myself. I have configured SSL monitors for our several production websites and monitors are all working fine on 443 port except for now we have decided to stop using TLS 1.0 and use TLS 1.1 or higher. Now the trouble has started because all my HTTPS monitors have stopped working with error: The server redirected to an unsupported protocol in IP Monitor.
So please help me how can i allow TLS 1.1 and higher support in IPMonitor.
Please let me know in case more information is needed from my end.
Dhyanesh Mehta
bkyle
Level 15
Re: How to Monitor https monitor with TLS 1.1/1.2 protocol
Jump to solution
Dhyanesh ,
Please open a case with our support team, and they can provide you with files that support TLS.
Jump to solution
Thanks a lot bkyle for getting back to me. I have opened a support case with Solarwinds so lets see what how they help. I will keep this question open until i find solution so i can ask all you experts for any query.
Meanwhile all suggestions are welcome if anybody has any regarding this case.
Dhyanesh Mehta
0 Kudos
bkyle
Level 15
Jump to solution
Were you able to get the newer TLS supported files?
0 Kudos
aeon
Level 7
Jump to solution
Hi Dhyanesh, did you get these files or procedure how to do this?
0 Kudos
Jump to solution
Hello Aeon,
Sorry for the delayes response. Yes i did get a buddy drop from Support. It includes support for TLS1.0/1.1 and 1.2. So you can open a support ticket and they should send you the required package.
Dhyanesh Mehta
0 Kudos
