I am new to this forum. I have a solar system on my house that uses a Kaco inverter. Kaco had been monitoring the elecricity production of my solar system. But now Kaco has been bought by Siemans and they are going to discontinue monitoring. Monitoring was done via an internet communication device installed in the inverter and sending data to the Kaco server to collect and display the daily production.
I was hoping someone here could point me in a direction where I could connect to the inverter's communication device say via telnet and collect the date. I am an amateur programmer familiar with C, C++, java and javascript. So I thought I could build an automated data collection tool to talk to the inverter, collect data and store it on my PC.
Any suggestions would be appreciated. Thanks.
Solved! Go to Solution.
It might be worthwhile to use wireshark to see what you can see traffic wise from the inverter. If you can figure out protocol, then you are on your way....assuming it is in the clear. If it is encrypted or through a https process, you may not have much of an opportunity.
doing a little google search and assuming it uses the Kaco proLOG you might look at this document: https://www.altestore.com/static/datafiles/Others/KACO_proLOG_manual.pdf
proLog is for large installations. mine is a residential and uses watchdog. Thanks anyway.
Please be patient with me as I am a novice at this. Using Wireshark, I can see DHCP and ARP packets to the solar inverter. DHCP when the inverter turns on and ARP periodically during the day. I have several things I need to work out:
1) decipher the packets (from manufacturer or current monitoring company)
2) send and receive packets from my own program
Any tips you might have on acomplishing this would be helpful.
Thanks in advance.
I quickly browsed the wireshark web page and this may be a solution. I will let you know what i find. thanks.
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
