cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Bandwidth Monitor - Seperate Up and Down
I have a 3MB link for our internet connection both up and down. I want an alert for when the full 3MB is taken for either up or down. This issue is that ipMonitor combines the values. So if I set the threshold at 3MB and the current link utilization is 1.5MB up and 2MB down, the threshold is met because total throughput is at 3.5MB when in actuality I have 1.5MB free for uploads and 1MB free for downloads.
Any way around this?
-Charles S
0 Kudos
Level 7
 I would like this also.
0 Kudos
Level 13
Hello Teecee,
In order to add you to the Feature Request and notify you if and when it becomes available, we will need you to submit a case at http://www.solarwinds.com/support/ticket.  You can also open a case, like Chaldz did, by calling the Solarwinds Support Department at 866.530.8040.
Thanks in advance.
Chris Foley
0 Kudos
Level 9
I would really appreciate if any one can answer this
If NMS shows switches interface is Transmitting 100 Mbps, what I would consider overall link utilization would be 50 % or 100 %??
0 Kudos
Level 13
Hi Chaldz,
This is currently a feature request.  I have created a case for you and attached it to the feature request in question.  I will notify you if and when this is implemented within a future build.
Sincerely,
Chris Foley
0 Kudos
Level 11
Has this been addressed in version 10?
0 Kudos
