cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
https using a wildcart certificate
Jump to solution
Is it possible secure all Web Helpdesk traffic with an wildcard certificate?  We just purchased one from Godaddy.com and Im wanting to secure as much internal information as possible with ssl.  If so where would I find instructions for this?
Thanks in advance!
0 Kudos
1 Solution
Level 14
Our install uses a wildcard at the local server from Geotrust and we have no issues. I believe the instructions would be here http://www.solarwinds.com/documentation/WebHelpDesk/docs/WHDSSL.pdf
0 Kudos
1 Reply
Level 14
0 Kudos
