cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 9
Ticket Routing
Question
We have a majority of tickets assigned to help desk then assign to a tech in a different group if needed. The issue is then the tech group the person is in does not see the ticket
even though a member of the group is assigned the ticket. Is there a way without changing the request type to be able to change the tech group on ticket so it now is assigned to
that group.
Thanks in advance for the help.
0 Kudos
Highlighted
Level 12
Re: Ticket Routing
escalation from level 1 to level 2 is the way
Chris
Highlighted
Level 9
Re: Ticket Routing
thanks Comtcjm but it escalates within that tech group. We want to be able to send to a different tech group without changing the request type.
0 Kudos
Highlighted
Level 12
Re: Ticket Routing
If you don't use escalation for other purposes, create different techs within level 2 of the same tech group, each level can it it's own set of techs. Level 2 can also include level 1 techs if required.
You can only align 1 tech group per Request Type, this is fixed by design.
Althernatively you could have an action rule, which picks up the changes of a custom field e.g. "Change ticket to team B", which modifies the level to an different level e.g. Level 5
0 Kudos
