cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Ticket History
In situations where the ticket history is cut off, is there anywhere to view full history of that event?
0 Kudos
Highlighted
Level 11
Re: Ticket History
You could try checking the database directly for more info. I believe that info is pulled from the history_entry table and should be in the entry_text column.  It might still show an abbreviated entry if the actions take would create a long enough entry that surpasses the table data type properties.
-j_a_catlin
0 Kudos
Highlighted
Level 12
Re: Ticket History
I would request a feature with SW to add a onmouse over with the text to show a hover box when you move your mouse over the text to reveal the whole history entry text
0 Kudos
